New Plan Trial
Holdem07
Hi,
If i try Visible for the free 15 days and decide to switch will i still get the promotional rate of $30 for the Visible+ plan? If I do go with Visible and I am under the plan for only 13 months and decide to terminate under the $30 promotion will i get penalized and owe any money back to Visible?
As long as you apply the SWITCH25 promo when signing up during or after the trial yes. You then choose the Visible plan. SWITCH25 currently expires on 1/31/2025.
No penalty for terminating - it's month by month prepaid (no refund on prepayments like most prepaid plans).
Note that the trial only gives you the Visible basic experience, not Visible+
