02-06-2023 12:30 PM
I have Visible unlimited plan. If I change to Visible + will I be able to make calls from Europe to the US. I am going to Italy, France and The UK.
02-06-2023 03:07 PM
No, the plus plan will only allow roaming or calling from Canada and Mexico. Some have mentioned to make sure Wi-Fi calling is working and switch to it before leaving the US but you would only be able to use it while connected to someone's Wi-Fi. Only other option is to get a SIM card when in Europe and I am not sure if you can get one that will work in all three places.
12-13-2023 05:53 AM
This is very disappointing! Verizon had a good European plan you could add to your account temporarily. I am not sure why Visible is not offering any type of temporary roaming plan for Europe.
