07-25-2024 12:10 PM
Hello,
I'm trying to setup a Visible account (moving from TMo postpaid) and have a unlocked iPhone 14 Pro. When I check the device, both eSIM IMEI numbers read back as incompatible with Visible network now. I don't think this should be the case, but not sure how to proceed.
Is it true that iPhone 14 Pro doesn't work with Visible?
07-25-2024 03:14 PM
You can find out if your iPhone is locked by going to Settings > General > About. If "No SIM restrictions" appears next to Carrier Lock, your iPhone is unlocked.
Since Visible uses Verizon, check if your device locked at to https://www.verizon.com/sales/prepaid/byod/enterDeviceIMEI.html
If it still says the phone locked, I suggest you contact TMO to release the lock.
07-26-2024 11:23 AM
Yes, Carrier Lock says "No SIM restrictions". The link you posted says the device will work with Verizon. I don't really understand why it's being rejected with the Visible checking system.
07-26-2024 11:24 AM
Sorry for the trouble, I just checked it again today and now the Visible device checker is working. So I'm not sure what the ghost in the system was yesterday.
