hot spot devices that work with visible
McAngus56
Does anyone know the best hot spot device to use with visible?
Moxie
Superuser Founder
Superuser Founder
Get yourself a travel router like a TP-Link AC750. But first, Go to you tube and find a setup (walkthrough) video.... it'll make total sense when you see it.
Good luck!
5 REPLIES 5
Moxie
Superuser Founder
Superuser Founder
What are you looking to do?...that makes a BIG difference.
Best!
I am going to try and run my house internet off of my visible service...I have been doing this for 3 weeks now and it is working just fine (I live alone, don't game online, just stream and surf). I would like to get an appliance that would act as an internet source  tethered to my router for whole house wi-fi.
Thanks for the reply
Moxie
Superuser Founder
Superuser Founder
Good luck!
Thanks for the advise and help
Hi everyone, Thank you for sharing your questions and ideas with the community. This is just a friendly reminder that Visible only allows service to be connected to authorized devices and it is not intended to be a home broadband replacement. -kh_jenn
