06-28-2021 07:19 PM
To All,
I have an iPhone 12 Pro Max & I noticed a Call Waiting Toggle Switch. Bread Crumbs: Settings>Phone>Calling Waiting.
Nevertheless, is this something that can be toggled on?
Thanks,
~Button
06-29-2021 03:48 PM
Hey there!
Call waiting is a feature include with your Visible service, so you can toggle it on or off if you'd like.
06-29-2021 08:55 PM
TJ,
Mine will not turn on. I receive an error message, 'Could not save call waiting setting'. Furthermore, my daughter's phone, iPhone 12 Pro, has the same error. I contact support & they ran me thru the gamete of troubleshooting including a factory reset. This did not resolve the issue so they are escalating it.
Good times,
~Button
06-30-2021 04:31 PM
Update,
Visible Tech open up a ticket & said I'd hear back with in 24 hours. Guess what, it's been > 24 hours & this is just for Call Waiting. Not a good way to start a relationship. I will keep y'all posted.
~Button
08-15-2021 05:08 PM
Here’s an interesting twist. Turned of Call Waiting in settings and could not toggle it back on. Got the “cannot save setting” message. I also tried the *43# code and that failed as well. Contacted CS through chat and was given the same procedures. The problem was sent up-line.
Received an e-mail the next day with same procedures listed. So, there seems to be no solution.
You might try #43# to try to turn on Call Waiting, but is doesn’t seem to work either.
04-09-2022 01:00 PM
I have an iPhone 11, iOS 15.4.1, and Visible eSIM
There is no Call Waiting option in Settings - Cellular or Settings - Phone
But Call Waiting is working fine
07-18-2023 07:49 PM
Same problem, half way through 2023.
09-19-2023 10:39 AM
My call waiting shows it's off, yet seems like every time I'm on a call, it gets interrupted with another call. And I can't turn it off because it's already showing as off. 2023 almost over, still no fix to this??? This is absolutely disruptive enough for me to switch to a different company.
