Moto G Stylus 2020
control-z
Hi,
 I told me friend I would join their party but for some reason when I enter my IMEI the form tells me the Moto G Stylus 2020 isn't supported.  It's a unlocked 4g Verizon-compatible phone and has been working fine on Verizon towers for 2 years.  Can this be made to work with Visible and if not is there a specific reason or it just isn't known if it works?  If it just isn't known is there a way to order a SIM and try it?
Try chatting with support directly, I have seen on the forums where phones are reported as incompatible but when potential customers chat with support, they are suddenly compatible.
May not work in your case, but can't hurt (use the chat with us icon in the below link):
https://www.visible.com/help/connect/
4 REPLIES 4
First it could be a few reasons.  1 Not all phones work with Visible.  2 As you stated it might not be known if it works.  The sim is free.  You can either check the savings spot board and grab a code and get your first phone for less then a cup of coffee.    You could also trade the phone it is called Visible's swap program or you could purchase a phone from Visible.  The link to the Visible shop is
https://www.visible.com/shop/smartphones
I can't seem to order a SIM.  Every avenue I take on their website or app asks me for the IMEI and then shuts me down.  Is there another way around it?
Thanks.  I was able to chat with them fairly quickly and they pretty much said that even though my phone works fine with Verizon towers, Visible's system/software doesn't work with it for whatever reason.  Oh well, I tried.
