Moving the whole family over to Visible from Verizon
bsmercier
I have a family of four with everyone having their own iPhone.  How do I port all four numbers under the same user account?  If that is not a function of Visible, how do I handle my two children having their own Visible account?  Thanks for the assistance.
4 REPLIES 4
Each number transferred will need a separate account and email address. As for your two children, as long as you use an email address for each of their accounts you would be in charge over it. The email address used for their account doesn't have to be their email address but one you generate for the account.
Just to point out, Visible does not have family accounts, they are single line accounts. The base plan, even though it being unlimited everything, is deprioritized when it comes to data. If you go the plus plan route on all four phones I would think Verizon would be the better option for multiple lines unless you are looking for truly unlimited data.
Hi, this is easy.  Each account will need its own email address.  Just do that and then you can use the same payment method for all accounts.  If I have helped please mark my answer as an accepted solution.
If you have a Gmail account, you can use a single email address for multiple accounts. For example, if your email address is abc @ gmail com, you can sign up for a second account using abc+visible @ gmail com. All emails will still be delivered to abc @ gmail com.
You can create additional accounts like this:
abc+visible3 @ gmail com
abc+visible4 @ gmail com
This way, you can easily manage multiple accounts while keeping everything organized in your inbox.
If you have a Gmail account, you can use a single email address for multiple accounts. For example, if your email address is abc @ gmail com, you can sign up for a second account using abc+visible @ gmail com. All emails will still be delivered to abc @ gmail.com.
