Not Receiving Texts
MMpitts8
I have not been able to receive texts. I had already powered down and
19 REPLIES 19
GasLit
This is annoying
This worked for me. Reset network settings. I have a Samsung S21
Thanks very much for the feedback!
GasLit
This is frustrating....EVERYTHING needs to send you a text to access.  I cant pay this bill for one thing.  You sure will shut down my services though.  Cant access my bank or transfer money.  This service is trash.
Were you able to get any resolution?  If so, what did they do for you?  I am having the exact same issue
Visible customer service was able to fix this issue as I was chatting with them on their customer support
This worked for me. Reset all network settings. I have a Samsung S21
chegberg
yep. in the same boat.  I am able to text between phones but can't receive from any website trying to send a security code.
I canโ€™t receive texts from Android users. Like many others, impacting my workflow.  Has anyone been able to get a โ€œlive agentโ€? I canโ€™t even log into my account because they send a text for verification-canโ€™t receive the text. This is maddening. Regretting the switch.
My husband and I are experiencing this same issue today.
Not gotten anything either. Already paid for this month, otherwise I'd switch to something else. Been happening for me since Tuesday.
Same issue here.  Can text between phones but can not receive security authentication codes.  I assume they are working to fix this?  Has anyone heard about that?
having same issue.  Were they able to help you?
I am having the same issue.  Were they able to resolve it for you at Visible?
chegberg
Yep. In same boat.  Can text between phones but can't get security codes from the web.
Superjock
deloze
I can't receive texts. Sending fine. Spent hours on the chat trying to get it resolved. Second level support is next.
