Wi-fi calling inquiry - Visible Community
toppito
I got the Wi-fi calling ready on my Iphone 13 Pro Max and setup my 911 address as required
How do I know if it is working?
On the top left corner of my Iphone where the carrier name is displayed....it is still saying Visible instead of Wi-fi calling....on my previous provider the carrier name changed from Mint Mobile being displayed on the top left corner of my Iphone to Wi-fi calling.
I need the Wi-fi calling because I am traveling to a foreign country....need to get SMS text messages from my banks while I am there. Will it work with visible? Wi-fi calling has worked with all the mobile providers I have had in foreign countries. Thank you
GreenSub
I would power cycle your iPhone.
My iPhone SE 2022 displays โ€œVisible WiFiโ€ in the upper left corner and it is running iOS 15.7
I am on the new $30 plan and using an eSIM.
A simple way is to put the device in airplane mode.
Then enable Wi-Fi alone. Now it should display Visible Wi-Fi.
For some reason Visible prefers to connect to cellular towers when network is available. It connects to Wi-Fi calling only when there is poor network.
please mark this as solution if it helped you
Cheers
