Will my Motorola Edge+ 2023 work on Visible network? Currently using Verizon
surrfman
You can check it here. https://www.visible.com/shop/compatibility
It should work but it might not pass their checker to get eSIM or pSIM.
rjniles
According to the Motorola web site -Yes
  • Compatible | Compatible & supports VoLTE, WiFi Calling
You say it was working on Verizon, it must be unlocked to work on Visible
