- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
โ08-07-2023 12:14 PM
Been overseas 6 months and had to deactivate my service.
I want to return to Visible upon arrival to the states.
Can I use the old sim and reactivate with a new number?
If yes, how do I do it or is it possible to do on the app when I get to the airport on wifi?
Thanks!!
PS looks like so much ha changed with the new plans lol.
- Labels:
activation
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โ08-07-2023 06:03 PM
Great question. I would contact support to find out what your options are.
My guess is, more than a month or two without service, you should choose a different email address than you used before and sign up for a new account with Visible.
If you take your service down again, and want to keep the number, consider porting your number to a place like https://www.numberbarn.com/. It works like "parking garage" for cell phone numbers. It is not free, but a nominal charge.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โ08-25-2023 05:02 AM
You know craftiness, with a little bit of patience you can hold onto your lines number. By going though the process of ordering another Physical Sim (P-Sim) you will be able to keep your old number so long as you are using an up to date device as far as hardware and installed visible applications are concerned.
An E-Sim may very well offer the same opportunity if you have a modern enough device.
Warm Welcome back home.
