CarPlay Not Working Properly
KevinThad
After porting my phone number to Visible, CarPlay is not working with phone calls in the car. Other Apple Apps are working good. My ported number shows up as “secondary” in cellular option. AT&T shows up as “secondary” as well. (No “primary” and I cannot reassign Visible to “primary”). There is no option under AT&T to delete that eSim. Thoughts?
Unknown_Finding
Hello,
Carplay not working has no correlation to Visible. This is a specific issue with your device.
Also, if you go into cellular settings it will show both esim profiles if you have two. If you disable or delete the one you are not using then AT&T will appear as normal.
