Disable International Roaming
Can you disable international roaming completely? Such that it does not connect to a tower or pickup a signal abroad?
I see the Visible+ plan offers a global pass, but I would like to make sure my line does not roam internationally, and rely only on Wifi-Calling (or use Visible over Cellular Data) using my iphone.
4 REPLIES 4
You have to specifically enable Global Pass (as well as autopay) for it to happen. Visible+ simply gives you one free 24 hour pass per month. Others as well as all on Visible basic you'll be charged as used if enabled.
See  https://www.visible.com/help/international-services for more details as to what happens in different circumstances when enabled (with autopay).
Visible is a prepaid service, so I wouldn't worry much about having a $$$ bill next month.
It works for the amount you pay. However I haven't tested how 1 day of global data works on Visible+ plan myself.
usatechexec
this is an important question - besides Global Pass - will your visible+ cell phone be assessed international roaming charges like a regular US post paid verizon cell phone would?  I tried visible chat agents - they never your question - they answer a different question. So where do you go if you have questions about visible? Its a bit confounding.
Did you ever get an answer or tried this?
