Solved: International Roaming - Visible Community
rlhartung
I will be working overseas for six months. Can i use international roaming on Visible+ for that long or is there a limit on how long i can use it?
Visible only provides international services (using your device and Visible+) within Mexico, Canada, the US Virgin Islands and Puerto Rico and then there are some limits. You need to rely on WiFi or a local SIM elsewhere. All other international service applies only to calling from within the US to select countries.
https://www.visible.com/help/international-services
