Discount Question
hdowell
How long does the $35/month or $25/month last? just a month? or as long as you use Visible?
Until Visible decides differently.
This is from the disclosure:
Discounted rate will continue so long as member maintains service on the Visible+ Plan or Visible Plan or until such time as Visible provides notice that the discounted rate has been discontinued.
