Email/Login hacked on Oct. 17 NO HELP at ALL
maddog6
As the title stats, 2 case numbers, both closed. 15 hours on chat, no help, promised call back from account manager, nothing. How does one go about getting this fixed?
beav
Superuser Founder
Superuser Founder
Two ideas:
-Visible has a rep on Reddit that will actually address issues. Their username is MVNOResearch.
-You could file an FCC complaint.
Another person was struggling with Visible, and here is what they did:
https://www.reddit.com/r/Visible/comments/q2urcd/number_porting_hell_even_fcc_complaint_not_working/
Good luck.
