β10-30-2022 03:16 PM
I got the dreaded "We're sorry, the number you dialed has calling restrictions that have prevented the completion of this call. Announcement 803" and saw a lot of messages from this board when I googled it, but the only solution I found was that someone had called in and a CSR had changed something that fixed it. So when I finally spoke to a CSR (after waiting for an hour) who took me through the standard list of things-to-try-when-you-have-no-idea-what-is-wrong, which didn't fix the problem but did change the announcement from 803 to 19, and then said he would "escalate" it and I should wait for an email, I figured that was the end and it would never get fixed. To my surprise, I got an email in less than 24 hours, requesting me to chat again, they needed more information. Fine, I started a chat, waited 1-1/4 hours, and spoke to another agent, who fixed it! I asked what he had done, to share with others who encountered this problem. He said:
"I just reprovisioned the SIM, if it happens again just ask for a sim reprovision and it should be fixed."
Something that you folks can try when it happens to you ...
β11-21-2022 10:39 AM
the fact that this is an ongoing issue, is beyond pathetic. I have unfortunately had visible for about 8 months now and it has been NOTHING but headache, & nightmares. If you're on the fence about getting Visible, DONT! STAY CLEAR AWAY FROM VISIBLE! US Cellular is a better option, really. They have better service & WAYYYYY better CS.
β11-28-2022 07:15 PM
This post was super helpful! After reading various comments about the β803β error I thought itβd take forever to get my phone fixed β I did need to wait about 1.5 hours for a response in the Help Chat, but once I did I asked right away for a βsim reprovisionβ as recommended above and after 20ish more minutes the issue was fixed, huzzah! Thanks for the tip, mamasylvia! You saved me days of customer service horror/frustration!
β12-03-2022 11:01 AM
I had the same issue today and asked for a "sim reprovision". Problem solved! Thanks so much for this information above. It saved a lot of time and avoided much frustration.
