Network icon or text
WPO1
Should there be an icon or name showing that you are on the visible network at the top of your iPhone?
SimpleSavings
Hi WPO1,
Yes, I have "Visible LTE" at the top of the screen on my iPhone 8 using iOS 14.8.1.
Thanks
Thanks
I now see if I pull up my control panel visible shows at the top left on my iPhone 13 mini
