β08-02-2021 03:17 PM
I have the winegard 360+ and the gateway 1000 router install on y rv. Will it be possible to a get verizon sim card for the gateway 1000 and use it a my router?.
β08-03-2021 03:52 PM
Hey there! At this time, cell signal boosters/network extenders/routers/etc. are not compatible with Visible. The full list of our compatible devices can be found by visiting this link https://www.visible.com/help/compatible/. If you're using Visible service with a compatible device, unlimited hotspot is included.
