Visible Payback Program - Visible Community
Anthony1
When should I expect to start seeing credits from the Visible Payback Program on my account? I was under the assumption I would start receiving credits once I activated my service. Visible support mentioned I have to wait 1 year from the start of my activation. Is this true?
Ace II
Did you read through the disclosure? I read through this and if you didn't buy it through or finance it through Affirm(see 2 below) then you are not going to get the credits. From what I have read you should be getting the credits monthly if you were eligible. Only other thing that is mentioned that would disqualify you is if you paid for service on the annual plan and you would not receive any credits. From what I have read you should be getting the credits each month. If not you would have to contact customer service again and hope you get an agent that knows what they are talking about. I did paste the disclosure below if had not seen it already.
Promotion is void where prohibited, taxed, or otherwise restricted. Visible reserves the right to change or terminate this offer at any time, with or without notice, including for any violation of Visibleโ€™s Terms of Service. If Visible, in its sole discretion, determines that a member has engaged in abuse, misuse, or gaming in connection with this offer, or that the member intends to do so, Visible reserves the right to disqualify the member from this promotion.
