โ02-04-2024 06:36 PM
How long would I have to activate a visible SIM card once received? I have a iPhone 12 Pro Max so was wondering if my phone is compatible too.
โ02-04-2024 08:33 PM
I can't 100% be sure but i believe it is 30 days from the time it is ordered. You could also do eSIM then you don't have to wait for a SIM to be delivered or have to be present when delivered to sign for it.
Phone should be compatible if it is unlocked. You can check it here. https://www.visible.com/shop/compatibility
