international roaming/whatsapp
jcampagna42
Traveling to Europe next month. I understand that Visible will not work while I'm there. I know I can get an International SIM card, but if I have Whatsapp on my phone, will I be able to call, text, etc?
WhatsApp is a third party app and just needs internet. So I would recommend you activate the WhatsApp while you are in US (so that WhatsApp verifies your number through SMS)  and then later while you are in Europe you can use the local European sim with internet to contact people on WhatsApp.
