2 weeks ago
2 weeks ago
If you are coming to Visible, yes, you can keep your number by porting it in, just make sure not to cancel your service with your current carrier before the port in is complete. There are instructions at visible.com on how to port in a number.
If you meant if you can keep a number you got when you started with Visible and are leaving, the answer is yes again, you need to port it out to keep it.
