โ07-26-2022 07:00 PM
Hi, this is Bob and please use my link to join Visible for $20 off the first month:
โ07-26-2022 10:17 PM
This code is not working. No friend/referral codes posted on this site work when activating new service. You will not get the additional $20 discount. Visible support is refusing to help unless you can provide the email address of the person whose code you are using.
Don't fall for this bait-and-switch. Wait until Visible is more honest about the referral program or fixes the issue before you join or activate a device.
