β05-19-2022 03:55 PM
I just joined Visible recently. I have a Pixel 5a using Visible esim. I only get about 5 Mbps even the phone showing full bar for 5G. LTE speed is about same. I live in Philadelphia area. I wonder what speed other people getting. Thanks!
β05-20-2022 07:27 AM
Iβve been with Visible 2 months now. Iβm a Speedtest junkie and used it multiple times my first month. I started noticing slower speeds too. Then I looked at my cell data usage on my iPhone. Those speed tests use a ton of bandwidth.
There may be a cap for higher speeds on Visible, I have no official info on this.
Anyway, I blocked the Speedtest app for cellular use. On my second month everything seems to be fine now.
Maybe someone in the know will comment if we have data caps before being moved to the 5 mb tier.
β05-24-2022 11:45 AM
This is one of the Downfalls if you want better service you will have to go with something like Cricket. I have complained about this for a while with Visible.
β05-24-2022
01:12 PM
- last edited on
β05-24-2022
03:16 PM
by
kh_jenn
So many people have abused the data (like replacing their home internet with Visible) that now it is capped at 5 Mb. Some people are grandfathered in and can still access the max-ton speeds... Not to worry, Visible seems to have a way to deal with that by making it difficult to pay your bill and ultimately canceling your account.
a month ago
The speed is mostly slow 5Mbps or less. I saw fast speed maybe 5 times. There are 2 times that there was no service (not due to location). I will just keep one line temporarily with Visible. Halting plan to move other lines over from mint or cricket for now.
a month ago
I am seriously debating how long I can keep Visible as my primary carrier. I have had call quality issues. I also notice data issues. I have complained to Visible and they haven't done anything.
