Can't send/receive MMS on a Pixel 4a 5G
anomalyrog
I just switched my unlocked Pixel 4a 5G from Verizon to Visible. I ordered the SIM card as an iPhone 8 and put it into the phone and everything has worked fine - calls, texts, internet.
But I can't send or receive MMS messages. I tried to look at the APN settings as some other posts suggested, but the only APN option listed is "Visible - VSBLINTERNET", and when I click the three dots menu there is no option to add new APN. Any suggestions?
4 REPLIES 4
Moxie
Try going to settings, reset options  and click on Reset Wi-Fi, Mobile & Bluetooth. Then power cycle your 4a.  If that doesn't work contact Visible to do a network reset.
Best!
Thanks for the suggestion.  I tried the reset followed by power cycle and it did not change anything.  I will contact Visible.
Just checking in, were you able to resolve the issue?
You can try going more extreme with a full back up then a factory reset...?
Best!
Contact visible support to do sim reprovision. Also check the compatibility of the device if it is supported by visible.
