08-23-2022 06:48 PM
I have an iPhone XS. Visible says it is compatible but then the IMEI is not compatible. I understand saying that I have a newer iPhone to get the physical sim card but are there any tricks to getting the e SIM?
08-27-2022 07:34 PM
No there is no way, because eSIM is in the hardware of the phone you can't change it, if they can't activate it with eSIM there is no way around
