06-10-2022 04:24 AM
Considering buying a Motorola One 5G Ace unlocked directly from Motorola. Visible sells the Motorola One 5G UW Ace. I chatted with Visible CS but all they say is test the IMEI# on the web site. Don't have the phone or the IMEI #.
Any one have a idea if the phone will work on Visible before I buy it?
06-16-2022 01:13 AM
If you really want that phone, either:
A) Find out what Motorola's return terms are, and buy it from them, then get the IMEI & submit it without opening the phone (it should be on the outside of the box)
B) Buy it from Visible, where you know it will work with the service
Good luck
