11-27-2023 12:49 AM
Hello there.
I see that the Palm phone (tiny secondary phone) is compatible with Visible service. Yay!
I would like to add it as a second device to my same phone number (as offered by Verizon
and other carriers). Because it is like adding an Apple Watch to a phone number... and Visible
is already set up for that process, I am assuming it will work the same way, but I'd love to confirm
before I purchase the tiny secondary phone.
Please confirm that: 1. Visible allows setting up a Palm as a second device with same number
and if not then 2. When will this setup be available?
Thanks!
11-29-2024 06:29 PM
Hi! Where did you see that the Palm is compatible with Visible? Were you able to set it up as a secondary device?
Thanks!
