Proceduring for setting up new account on a phone ... - Visible Community
Proceduring for setting up new account on a phone purchased online
kyleknapp
My wife's Galaxy S9 is not compatible with Visible (I checked the IMEI), so I'm thinking of buying her a refurbished phone online. Is there a procedure for setting up Visible on a newly purchased phone that includes transferring all her data (apps, contacts, photos, etc) over from her old phone?
Nothing specific to Visible - but there are several ways to go about it dependent on your situation. For starters, see: https://www.howtogeek.com/440556/how-to-transfer-apps-to-a-new-android-device/
A Google search will yield others...
I recommend purchasting from Visible directly.  This way you insure compatibility
rjniles
There is no assurance that a phone you purchased on line will be compatible.
