Unable to accept calls
danne77
I ported my number from Google Voice 3 days ago and everything went smoothly except for one issue. I can't receive any phone calls. The caller gets a busy signal and then the call disconnects. I can call out, send and receive texts (although automated texts for 2FA don't come through) and data is working fine. I've chatted with customer care twice and still no resolution. I appreciate any suggestions or help.
Thanks!
GreenSub
Weโ€™re you able to receive calls on a Visible temporary number?
Have you gone to GV and made sure forwarding is not enabled?
Have you done a *73 on your phone to remove any call forwarding?
