Voicemail setup
richman
I just switched over from AT&T Prepaid and I can't seem to find any instructions on how to set up voicemail. Can someone point me in the right direction? Sometimes, calls I receive go straight to voicemail without my iPhone even ringing. Does anyone else have this problem?
beav
Superuser Founder
Superuser Founder
Here you go:
https://www.visible.com/help/How-do-I-access-voicemail
Reply back if this does not answer your question, and we can figure out another option.
TheCellTower
Intermediate III
Others experienced the same issue so far no solution maybe apple has to send out a update
