โ03-29-2022 03:15 PM
How does the internet feed get from the phone to a computer?
โ03-30-2022 12:58 PM
Probably the easiest is to enable mobile hot spot, on apple it is called personal hot spot under settings, on the phone. Depending on your phone there are different ways of doing that. You will need to find the name (SSID) of your mobile hotspot and password. After that use your computer to connect to the wireless network that has the same SSID your hotspot.
Some other methods are using a USB cord or Bluetooth as well.
