06-04-2024 07:09 AM
Our family recently switched service from Verizon to Visible, after Verizon jacked up our rates. We live in an area with a very weak cell signal, so we are dependent on wifi calling. Ever since we switched, our calls are constantly being dropped or simply not going through. I've looked through the previous posts on this issue and haven't found anything new that we haven't tried. We all have iPhone that have the latest update installed. Please help.
06-05-2024 07:29 AM
Update - I started a chat with support. It turns out that Visible had our wifi calling disabled on their end for whatever reason. They enabled it, and it seems to be working now.
06-04-2024 05:44 PM
Sadly this is a problem with Visible. I had a lot of calls drop and always thought it was the other persons provider. I left Visible and am on Cricket with no call dropping and more than 4 times faster data speeds even at peek times.
06-05-2024 05:41 AM
Hello. Sorry to hear about your experience in WiFi calling. My experience in WiFi calling is also not pleasant with my current name brand carrier. If I connect my phone to WiFi and WiFi calling is on, the call is choppy and sometimes I had to end the call and turn off WiFi on the phone and redial to continue my phone conversation. My call with just a minimal cell signal is better than with WiFi calling! So, I think there is a tweak in the WiFi router called "QoS" to prioritize traffic. And I don't know what kind of protocol the WiFi calling is so I haven't tweaked my WiFi router.
06-05-2024 07:29 AM
06-05-2024 07:59 AM
Good job. You did the right action - contact Visible support. I know in my case of asking if the trial (I'm on the 15-day trial) allows for multiple device to connect on hotspot and I got conflicting answers. Then finally an agent with initials CB intervened and clarified to me that the trial only allows for one hotspot connection. And, when I finally join with a Visible plan, $25 or $45 monthly, I can connect more than one device on the hotspot. Anyway, I'm on my 7th day of the trial and hopefully when I finally port my number I can connect two or more devices to the hotspot.
Oh, as I have said, I don't call WiFi calling because voice quality is not good.
06-05-2024 08:39 AM
Awesome to see you got it resolved. Visible CS can fix the simple issues. They still struggle with the more complex issues. |That has been a problem for years. If you don't believe just look back in the forums. There is no reason you should be without service for 2 or 3 days. There is no reason you should do 10 hours of chatting and the issue isn't resolved. There is no reason you should have to do steps 1 through 10 multiple times. This is Visible's biggest problem. I still say they need phone support.
06-05-2024 08:50 AM
I'm confused! In this thread, nobody complained of 2 to 3 days without service, no one complained of 10 hours of chat! What are you talking about? I though you left Visible and yet you are still lurking?
06-05-2024 10:53 AM
Not everyone has a bad experience with Visible, I would guess it is maybe 1 in 1000, but what carrier doesn't have customers that don't have issues. I see this type of bashing on Reddit also from those that are no longer with Visible but have to troll the pages and put them down.
There have been a few reports of some having issues activating and spending hours on chat getting it resolved, usually it is likely a mistake made by the person porting in, but you never get the full story. The deal with not having service could be his phone or a tower being down for maintenance. The latter would have been easy enough to check by chatting with Verizon customer service.
I have said customer service isn't the greatest yet they try their best and the majority of the time they can get issues fixed. Bad thing is everything is done by chat and messaging them and I am guessing they are handling upwards of 10 customer at any given time. I have even had multiple agents chime on on the same conversation. With that said if you are one that needs someone to actually talk to by phone you might want to find a different carrier.
I have been with Visible coming up on 3 years and I have had no issues with service in that time and currently on the base plan. I live in a rural area that only has two towers and I only get 1-2 bars signal and it still works great for me.
06-22-2025 04:44 PM
@WindyKnobbI agree with you I left Visible do to not being able to get humans and dropped calls. I don't have time to waste. I went to Cricket and won't come back most likely.
06-22-2025 04:57 PM
So why are you responding to me on a one+ year old post and the other question is why are you even still here? Quit trolling and just get over it already!
06-22-2025 04:40 PM
I tried to start a chat with a support human agent but the screen required that I use a different device, to which I do not have immediate access, so all the time I wasted trying to get to the place where they actually offer to connect me with an actual human, was completely squandered. I had no other option but to close the chat?!
Then I was presented with a form to review my support experience, but that form was itself broken, presumably because no JavaScript but I’m on an iOS, with all of the content blockers dissabled and there is no specific option related to JavaScript, so again, I had no other option but to close the feedback form. …at which point I’m starting to notice a pattern with Visible support, which is this: it will waste your time and then fail for specious reasons, then it will ask for your feedback and waste more of your time, before even the feedback form inevitably fails, leaving you wondering why you ever bothered with Visible support on the first place, and maybe why you ever signed-up for their service as well.
All in all, my experience has made me reconsider my recent choice of carriers.
06-22-2025 05:04 PM
I'll respond to you directly. If this is a shot at me. I just left with in the last 30 days so my comment is relevant! Second people need to know the support they will get from the user forum is wonderful but the user forum can't resolve everything. You may or may not get good support from CS. If Visible could fix its issues it would be a wonderful company!
09-04-2025 05:19 PM
Need help on WiFi calling
