Determining data usage
FrankB
How do I check how much of my data has been used in a month?
I assume the Visible App should tell me that, but currently the Visible App is not available for download on Google Play.  I tried to install it when I registered this phone a few days ago, and the nice lady on the chat had to remotely activate my SIM because the app was not there.
Thanks!
Frank.
rjb219
visible doesn’t display data use. Your best option is to use the built in data counter on your phone in the settings.
rjb219
SimpleSavings2
Intermediate
Visible doesn't display data most likely because data is unlimited. I agree with rjb219, your best bet is to look up data usage in your phone settings, which may not be exact, but should be pretty close.
Welcome to Visible, btw.
