I am able to receive SMS meow - Visible Community
z1657062
Was able to chat with a rep and they had me just toggle airplane mode off and on for 30 seconds. I am not sure if they did anything on their end but that worked for me. If that does not work, last night I did reset my network settings so try that is well and then toggle airplane mode on the second try. You probably have time to wait in the chat line while trying all this anyway so give it a try. Chat with them on your PC if you can.
robdutchdonegan
Same her spoke tweeted with support this morning, reset network, toggled airplane mode them powdered off for 5 minutes. I believe support also did some change on their side and now I get text. No text that came in while I couldn't receive text came back through so don't expect to see those.
