09-10-2023 05:22 PM
Hi folks, I love Visible but there's one mystery that I haven't solved. It seems that the mobile hotspot caps usage to two devices: the phone itself and one other device. If I want both my iPad and MacBook connected to the internet via the phone, I'm out of luck. I have to disconnect the one before connecting the other.
Seems like I used to be able do this, but now I can't. GitHub says the connection cap is with the carrier, which in my case is Visible. Has anyone else seen this issue? Any suggestions for a fix?
