โ06-23-2023 03:25 PM
1) I bought an unlocked Moto 5g Stylus from BestBuy. It worked flawlessly with my old visible plan(party pay).
2) Last week I was forced to upgrade to so called better plan with same rate($25) with free phone it works on new phone.
3) The problem is when I insert this new chip in Moto 5g Stylus only voice and text works. Hotspot could not be turned on. I get error message checking subscription and ask me to call Verizon.
It worked with old chip and old plan but new chip blocks hotspot.
I tried everything but could not turn the hotspot. I like Moto 5g stylus (256gb) and continue to use it.
Any help will be highly appreciated.
โ06-23-2023 06:09 PM
The issue is likely that it isn't a Visible model phone. Unless Best Buy sold you a Visible model phone the model numbers are different for the same phone that Visible sells. It has slightly different software programmed to it for phone made for Visible versus the same phone sold by Best Buy or the other big 3 service providers. I know this for a fact after chatting with Motorola customer service about 4 months ago about this issue with their phones not compatible on Visible even though they sell the same phone. If it is asking you to call Verizon did you buy the phone unlocked from BB. You can see if Visible customer service can help you out but if it is locked to Verizon there isn't much they can do.
Only thing I could suggest is trying to do a network reset, Visible will have you do the same and see if that fixes it. Make sure and change you hotspot name and password back because a network reset will erase that and add a new one. Other thing to try is doing a factory reset if you are willing to go that far.
โ08-08-2023 12:13 PM
Thank you for replying to my issue.
1) This phone Moto 5G Stylus worked on original $25 friends an family SIM card flawlessly for TALK TXT HOTSPOT EVERYTHING.
2) When visible forced in new VISIBLE plan the new SIM works just for talk text. HOT SPOT NOT WORKING
3) This new SIM does not allow hot spot to work. They sell the same phone.
4) I spent 2-3 weeks chatting and it does not help.
Only visible can answer this issue.
