08-22-2022 12:19 PM
My current card is provided by j1simcards, is it valid to get the Gift Card by porting my number from this carrier?
08-22-2022 07:18 PM
Really your not eligible for the gift card, but let me tell you a secret don't tell anyone😀 if your sim is using T-Mobile network or att network visible has no way of knowing if the number came directly from T-Mobile or att it the number came from a dealer/reseller if you put in your number comes from T-Mobile your gonna get the gift card, I take no responsibility in this act I'm just saying the fact
10-28-2022 04:41 PM
Have you tried it. I was planning to port in to eligible carrier and then again port out to verizon but what you are saying is correct then I won't have to go through that hassle
08-23-2022 12:21 PM - edited 08-23-2022 12:21 PM
Port in to another network who qualifies and then port back to Visible. There is no obligation that you have to stay in the other network for a certain time before porting. Cost associated would be from $10 to $30.
Refer this link for the list of eligible mobile operators.
https://www.visible.com/help/port-in-promotions
