Sims card
Acentore
I signed up for new Visible service on June 23. Can you tell me how I get a Sims card or how I can activate without one I have an iPhone 11
RyanBlakeIT
Hi @Acentore - You can either have Visible send you a SIM Card or you can sign up with eSIM.  It should've asked you during the purchase and you can confirm which one you chose when placing the order by going to your order history on your account (you'll need to log in).  If you chose eSIM, you just need to install the Visible app on your iPhone, log in, and follow the prompts to get it installed on your phone.
Hope this helps!
