11-26-2024 06:01 AM
I am on Visible Trial and installed the eSIM on my device. Now I need to switch this eSIM to another device. How can this be done? Does the following work?
1. Disable the eSIM on device 1
2. Download Visible app on device 2, sign into the account
3. Install eSIM on device 2
4. Enable eSIM on device 2
Thanks.
David
11-26-2024 11:30 AM
AI assistant says yes but take it with a grain of salt:
To move your eSIM to a new phone during your trial:
If not simply signup for another trial with the new phone's IMEI and a different email address.
11-26-2024 09:05 AM
11-26-2024 09:48 AM
I don't think it is possible to transfer a trial eSIM to another phone, I could be wrong but from my understanding the trial SIM is one time use in one phone. If you want to try Visible on another phone you would need to sign up on another account and use that phone to get the free trial.
11-26-2024 11:30 AM
