Switching family from Verizon to Visible
shveckle
Hello, what is the quickest way to switch 4 phones on a family plan from Verizon to Visible together porting our phone numbers over?  -Lara
That depends.  Are your phones esim compatible?  If so that would be the quickest way.
Airwolf
For me the thing that took the most time was the porting of the number over from Verizon to Visible.  I do not think e-SIM versus physical SIM would have mattered much.  If you are not keeping numbers then yes, E-SIM could be same day service.
I do not think you can have multiple phones on one account on visible, so each phone would have to have its own account on visible.  Which I believe means unique email address.  You can use the same method of payment on all accounts, but there would be a transaction for each account.
