Ubgrade plan
Fijolito
I want to upgrade my phone however I replaced the screen and the body is a deferent color then the original. will visible still accept it?
If you are a current customer and have been using the phone already it won't matter that you replaced the screen the phone should still work.
If you are thinking about becoming a customer than you would have to check to see if it is compatible here:
