Visible and 5G home internet
raziel00
I am in the process of moving from Verizon's family plan to separate accounts on visible.  However, I also currently have Verizon 5g home internet on my Verizon account as well.  What do I do with my 5g home internet when moving to visible?   Do I need to just cancel that home internet and start over with getting it from visible? Cancel it, turn in the equipment and just start over completely with visible to setup home internet?  Is there another path to take here?
  • 5g
Visible doesn't have any internet plans so switching it to Visible is not an option, they only have smartphone plans(and Apple watch add on). You can keep Verizon home internet and just keep paying the bill. If you had any discount through Verizon you might lose those. Visible does offer a discount for VHI and even though it says in the terms that the discount is for new VHI customers you can actually get the code and contact Verizon and from what I heard they will add it. The discount Visible offers is $5 off if on the Visible base plan and $10 off if on the plus plan. I think you have to contact Visible customer service to get this code once you have activated on Visible.
