Visible App Issues
ramcmah0n
During my porting process, I ended up with no cellular data access. I have found that you cannot get to the Visible app login screen without cellular data working. It says I am having problems and to try again
I need to redownload my eSIM.
Any solutions?
One of the steps in the process is that you need to be connected to wi-fi to be able to activate the SIM.
He said he was without cellular
You can use the app on wi-fi, you actually have to in order to activate using the app. No way around it.
