10-13-2023 07:11 PM
I will be out of the US for a month but will have WiFi access occasionally as I travel. I have turned on "Wi-Fi calling" for Visible on my Google Pixel 7 Pro phone. Will I be able to make calls, send/receive RCS messages, check emails, etc., while I am on WiFi in Europe? Or does that just work on WiFi when in the US? Seems like it should work on WiFi anywhere?
10-14-2023 03:41 AM
10-14-2023 03:41 AM
As long as you have WIFI, all our services will work.
10-14-2023 09:17 AM
Excellent! Thanks for the quick reply!
Saturday
I’m in Canada right now. I had my WiFi calling turned on before I left the USA. Now I can’t make WiFi calls and the option is turned off with no way for me to turn it back on! Help!
