โ09-15-2022 12:13 PM
iOS 16 has the ability to transfer eSIM data from phone to phone via Bluetooth. Does the Visible system support this process or do they require that you contact support?
โ09-15-2022 12:27 PM
The question is if it goes through the carrier or apple does it by it's own. If it goes through the carrier the carrier has to support it, if it's a internal change btw phone to phone and apple does everything then it should work
โ09-15-2022 12:42 PM
This is from Apple solutions. Hate to have to go through Visible if I donโt have too. Some carriers support SIM transfers from your previous iPhone to your new iPhone without needing to contact them. You can also convert your current physical SIM card to an eSIM.
If you don't have access to your current iPhone, contact your carrier to transfer your eSIM.
While you're setting up your iPhone, if you're asked to transfer your SIM, follow the onscreen instructions to transfer your physical SIM or eSIM. If you need to transfer more than one SIM to your new iPhone, transfer your additional SIMs following the steps below.
โ09-16-2022 04:35 PM
I just tried with my iPhone 14 Pro and it does not work.
โ09-16-2022 07:12 PM
same! ive been trying to contact someone about transferring my eSIM
โ02-04-2023 06:15 AM
has this been improved? Has anyone tried it recently? If you tried it recently when did you try it?
