Apps not working on network
Jkwong
None of my apps on my iPhone are able to work while on their network. I have full bars and 5G UW, their top tier. When I log into a Wi-Fi, everything works again. When I was in trial, with a temp number, all of it worked. Now that I’ve ported, none of my apps work unless on Wi-Fi. Only texts, calls, and internet works. Can’t get maps or even their own app to work. Anyone have a solution? I’ve restarted and hard reboot my phone. Still nothing.
RyanBlakeIT
@Jkwong - Is this still an issue for you?  If so, are you able to use a web browser to surf the internet without WiFi?
No, one of the IT support people reset the network for my phone and had me do a full reboot. This solved it. Thanks for asking.
