โ02-22-2023 01:38 PM
โ02-22-2023 04:18 PM
Go into your phone settings and make sure mobile data is turned on. When I upgraded for the old Visible unlimited plan to the new basic plan I couldn't get data either and didn't realize when I removed the old card and activated the new that it toggles the mobile data button off. As for picture text not sure how to help there, maybe try doing a Google search as it might be a setting on your phone that needs to be changed.
โ02-24-2023 07:24 AM
Yeah there is a major issue with the upgrade and they're obviously lost with how to fix it and are lying to their customers
โ02-24-2023 01:57 PM
Is this an Android and can you edit your APN settings?
If so, search this forum for some unofficial APN settings.
