Galaxy a54 - Visible Community
Galaxy a54
Tdelo
I have a galaxy A54 G5 .   I wanted to switch to visible but it says my phone isn't compatible.   It's unlocked.
I see you can buy the same phone from Visible.   Why is mine not compatible?
beav
Sometimes the IMEI datatbase on the Visible website is not up to date. You could do the following:
-Reach out to tech support via Facebook or Twitter DM and ask them
-Why don't you give the free trial a spin: https://www.visible.com/free-trial/
